- 10 Jan 2012
yeah....i downloaded a different evo ENB and its working fine now..god knows what was wrong
I'll have a look at that one, it looks nothing like the screenshots for me but has promise. Very burry though, I downloaded GTA4 to try that out anyway.This ENB is quite popular,i tried this a couple weeks ago but problem for me was it was a bit oversaturated,its seems to work though for a lot of people,give it a try,maybe Skyfall could try it and tweak it for some of you guys.
Gionights ENB.
http://www.gta4-mods.com/misc/gionightss-best-enb-final-f9889/
just about to install the steam versoin of this game, i have downloaded the final version on enb as recommended here but i cant find a working link anywere to DKTs new road textures....
does anyone have this file they can upload somewere please?
thanks
Has anyone had difficulty installing on Windows 8?
I get the message "Your system is incompatible with GTA IV".
I've tried running in compatibility mode for Windows 7 which has the same result while XP mode just crashes.
Error screen I'm getting can be seen below...
https://skydrive.live.com/redir?resid=5B1B99F693806987!190&authkey=!AApJmavFtF428dI
I only have a 2.5mb connection lol
As for the downgrade its really simple, download the 1.0.4 patch from here
http://www.gamefront.com/files/14266711/gtaiv_patch_1040_zip
Just run the update and it will install itself to the right location, then you need to download the Rockstar Social Group tool. The link is below towards the top of the post, point 3 it is, once you have downloaded this DO NOT INSTALL IT YET!
http://www.gtagaming.com/forums/showthread.php?t=128300
So now you should have installed the 1.0.4 patch ontop of your fresh GTA install, go to your GTA IV directory mine is below but your see the idea
C:\Program Files (x86)\Steam\steamapps\common\Grand Theft Auto IV
In this directory you will see 2 folders, GTAIV and Installers. Rename the GTAIV folder to something like GTAIV bb or whatever you choose it really doesnt matter. Once you have done this install the Rockstar Social Group tool you downloaded earlier. This will now put another folder into your GTAIV directory so you will now have 3 folders in there: GTAIV (the one the Rockstar Social Group tool has just created) Installers and GTAIV bb (the one you renamed earlier)
Now just copy everything from the new GTAIV folder that was created into the GTAIV bb folder you renamed earlier. Once you have done that delete the now empty GTAIV folder and rename the one you changed earlier back to GTAIV JOB DONE
Any problems let me know
