- 16 Nov 2010
- Swimming in a lake
Watch the Deadlift vid in the exercise gym thread and take notesI do that every so often still.
Your not getting tight on the bar for deadlifts before you start the lift, and your back isn't neutral. You could do with your head being a little more neutral then it is, this is one of my bad habits to. As for the dead portion of the lift well your barely even tickling the floor between reps, you need to put the weight back on the ground and get tight on the bar again and go again, your currently doing touch & go. More to be said but watching the vid should help you out![]()
Yeah, I reread the stuff again, and realised just how much I'm missing. I feel like I need something to etch this into my brain. May actually write down methodology on a piece of paper and stick it between my feet.
KD
Firstly, put the weight down between each rep, reset and lift. A deadlift by nature should be lifted dead, not touch and go and definitely not even touching the floor at all.
Your initial setup isn't great - watch thishttp://www.youtube.com/watch?v=a-DJu0bEVPw
On the neg, push your hips back more.
Need to work on keeping the core tight and controlling your spinal position.
Right, have now watched this (about ten times), and re-read plenty of stuff, alongside setting up without a bar, and pretending there's a bar in my hands.
I'm kind of hoping I've got more control of it now, and the aim is to get back to the gym tomorrow at the earliest, Tuesday at the latest, and reset up with again, not massive weights, but something that allows me to set up properly, and I'll try and get another video up.
Just saying really mate, your lower back probably shouldn't be movibg like that in a normal situation let alone with a weight attached to itluckily you don't lift it in that position, just a point to note
Aye, that's probably true, my back has got used to being all kinds of moving from butterfly. Not quite so useful here xD Seems the cost of shoulder mobility
Has anyone got some good stuff bookmarked on hamstring mobility? Definitely seems tight setting up just now. I'd certainly have to start bending knees before I can reach the bar, that's for sure, and actually, any kind of toe touch exercise I'm dire at due to hamstring tightness.
kd
