S'ok - the question was aimed at Skeptic...
If he wants to be a powerlifter and lift weights to... errr... lift weights, then low bar is fine.
If he wants to get the most out of squatting for athletic purposes (i.e. to help make cycling,running, whatever) and become more awesome, then high-bar or front squatting would be better because of the greater flexion (ROM, and therefore extension) across the various joints.
Is a high bar squat superior for quad development?
Scott any ideas would be great! I seem to have a issue with my left/right chest/shoulder balance. For example you can majorly see it on the press machine, my left shoulder when I push is significantly "higher" than my left? Or another one would be bent over rows, when I pull up my left side goes a lot higher than my right and seems the stronger side even though I'm right handed. Any idea? Thank you![]()
Heh, I have the same thing actually, I can press better with my left than my right, but my left arm will fatigue quicker sometimes...
Noob guess at hammering your lats and surrounding apparel?
When doing CGBP does the bar have to touch my chest?
Ball in your anterior deltoid. If you don't scream, you're not doing it properly (as Delvis suggests - everybody has gash tissue in their delts.).
That, and pec major/minor, as well as lats, posterior delt, and maybe even trap, too. I anticipate activation of tear ducts, and high frequency vocal chord vibrations.
I'm just going to invent a soft tissue tumble dryer for humans or something.
Client: I have a tight knot in my trap
Guru: Just go in the soft-tissue-o-matic-1000 and hit EVERYTHING!!11
Take another video, try and get your entire body in frame and show your setup. Have you watched the video in the OP? You are setting up too high currently, shoulders should be in line with the bar not in front. Head should be tucked not up.
Edit:
Found this old image, Delvis had the same issue.
Hmm. I thought I was doing that? Pulling on the bar during setup to take the slack out and engage lats?
