Hi all, couple of vids for a form check. Sorry about the angles, it's hard to find somewhere to rest the phone.
Squats
Side View
I think I need to sit back more into the squats.
Back View
I might try a slightly wider stance aswell for the squats.
Deadlifts
Deadlift
Any comments/improvements please, training log can be found here
My squat form for critique
From my untrained eye:
Neutral spine issues. I can't see any core bracing going on which shows in that you do not maintain a neutral spine through the movement. Your back goes in to extension as you descend, this might not seem like a problem at this weight but it will cause you all kinds of issues. If you feel like you've worked your back after squatting, this is likely the cause from my experience. There's also the issue of the butt tuck and you bending your neck to look in the mirror as your torso naturally leans. Craning your neck up like that would bring an end to any neutral spine you had going on if you were bracing your core properly. Not sure on what could be causing butt tuck at the moment, my mind has gone boom.
Your shoes, are they cushioned soles? If they are then get rid of them, the sort of movement where you are pushing in to the ground (deadlifts, squats, almost anything really) will really suffer as you'll have a hard time producing torque.
It's not totally clear from the video but your knees don't look like they're being really forced "out". Try squatting with your feet facing straight forwards as opposed to slightly outward, and as part of your core bracing when initiating the squat then externally rotate your femur. Your feet shouldn't move but your knees will now point very slightly more outward. You should be able to tell if you're doing this right as your foot will majorly arch and you'll feel your hips turn on. Then, during the squat, focus on getting the knees out wide.
Bar slightly too high, try to get it a couple of inches further down.
Good work, chaps -knees out!
Fixed.
Move the bar slightly lower.Another attempt at a squat form video...
Still working on my depth which I think has got much better but obviously there's still room for improvement.
Depth aside how's it all looking?
I have a really wide stance and my feet are apart a bit, any closer and I get zero depth.
Should I change my stance to closer and do some mobility work or keep the current stance?
Edit : This was my 7th set so I was a bit tired
Unfortunately not good mate.My squat form for critique
Squats:Hi all, couple of vids for a form check. Sorry about the angles, it's hard to find somewhere to rest the phone.
Squats
Side View
Back View
Deadlifts
Deadlift
