These zigbee plugs are weird. Red light when off and green when on![]()
Is that not a normal combination of on and off indication for colours lol?
Sorry wrote that the wrong wayIs that not a normal combination of on and off indication for colours lol?
I'd try and hack it electrically TBHHas anyone purchased/using a switchbot or similar device?
I've got a device that has a button that needs to be pressed in for a few seconds to activate, from what I've seen from the likes of these devices they can push down on a button, but they don't really say if they'll push and hold or just push.
.I’ve moved all my hive gear over to z2m. Only thing I had a problem with was a window/door sensor. It would add ok and work but then randomly not work every now an again and in z2m it never seemed to fully complete the interview process no matter how many times it was re-added.I've kept the Hive thermostat on the Hive hub. I can still control the temperature through HA though. Reason being is exactly what you have said. I don't want to lose the ability to heat home if HA goes down.
That makes sense. When the temp reaches the set temp during the schedule, does the heating cut off?I’ve moved all my hive gear over to z2m. Only thing I had a problem with was a window/door sensor. It would add ok and work but then randomly not work every now an again and in z2m it never seemed to fully complete the interview process no matter how many times it was re-added.
With the hive thermostat a receiver, I’ve used the scheduler card to create heating schedules. If my HA did go down, it still works fine using the thermostat itself to change the temp, boost etc.
Must have had an electrician on the design team (green = safe = off).Sorry wrote that the wrong way
Red when on green when off
What HVAC system is it out of interest?
Any recommended espHome module with camera
If I follow you, then you can create a template to multiply this or you could just use a component like this:I have discovered Tapo Control which seems like an excellent way to integrate energy monitoring plugs - the P110s specifically.
I'd like to make the energy cost "in your face" though, is there a simple way to multiply energy cost today by the unit cost?
I hacked some code together yesterday which worked great for about 7 hours and then stopped for some reason. This approach looks much simpler. Thank you, will give it a go!If I follow you, then you can create a template to multiply this or you could just use a component like this:
Utility Meter
Instructions on how to integrate the Utility Meter into Home Assistant.www.home-assistant.io
Latter has some extra bits likes tariffs built in to deal with cheap periods, expensive periods etc
This what you meant?
Having had a bit of a tinker with HA in recent weeks, I've now got various services and devices hooked up to it which is great, and I'm looking forward to the summer when I finish my diploma and will have more spare time to tinker with it. But I'm also thinking about what else I can integrate...
So far I have:
Lighting (hue and ikea)
Various smart plug sockets for fans, electric blankets, lights etc
Google Home Minis
Wiser Heating
Plex
various media players
Tile key fob
Garmin Connect (sort of)
The only automation I've had time set up is a motion sensor to turn the landing light on and off based on movement and the time which is working pretty great. I will probably get more motion sensors to have this functionality in other areas like the kitchen etc.
I'd like to get something like Google Fit or Fitbit integrated as I'm trying to get my weight back down (a few years ago I lost 6st and through bad mental health, medication and a lack of time/motivation it's crept back on) and I like the idea of being able to see charts etc on Home Assistant to remind me and show me how I'm doing!
I'd also like to try to get some sort of automation working to get my heating to go to away mode when my Tile key fob is not at home...
But beyond those two ideas I'm now trying to think what else I can add to my set up to tinker with. I don't have smart meters so anything relating to that is out but I'm open to other ideas if anyone has any?
It does indeed and then comes back on if the temp drops below that in the time it is set to that temperature.That makes sense. When the temp reaches the set temp during the schedule, does the heating cut off?
Ooh, I'm plotting the same - thinking of using ESPHome to control the water and this'll then integrate nicely with HA scheduling.I approach automation in a few different ways for new ideas:
- repetitive chores around the house/garden
- energy saving
- security
- something just because it's cool
If electronics is a bit of an interest, I'd suggest having a play around with esp modules and esphome.
I'm working on a smart irrigation system for the greenhouse for when I start to grow things this year. It's a repetitive chore having to water plants, I sometimes forget, or I sometimes overwater them. The idea of a smart irrigation system takes all that away and will only water the plants based on their moisture levels.
