Im cooking in just a standard oven in kitchen, It was just the peel I have was the ooni
Ah ok
The dough I make using the video at top of page is great, it's just the sticking that was the problem, hopefully the wood peel will make things easier.
It will still stick you need an anti sticking agent like cornmeal/polenta or flour, I go for cornmeal because it gives the base a little extra texture when it comes out cooked
How do you guys store your pizza dough?
I normally make just enough for 2 pizzas.
I have to small glass containers I use and normally use a little olive oil and place in fridge and use no longer than a week.
My recipe usually makes enough for around 4 pizzas but I often double that with guests. Got a large tub for proving in the fridge which I think it just a big cake box. Then a big dough tray for proving when shaped into balls which holds around 8-10 dough balls.
If there is any left over I shape back into balls and cook in the oven, makes okish bread rolls.![]()
I just loosely cling wrap the dough balls, no oil, doesn't stick - and then use that cling to cover them as they come to room temp, and as they sit on board before final flattening/dispatch.
Hey folks, just recently joined the forum but it makes me so happy to see the Ooni love here. I've got a Koda 16 here at home and it's an amazing beast of a thing!
We freeze ours. If you let them defrost for 5-6 hours on your worktop then they'll be perfect for when you start stretching. That said though, whilst I started out making my own dough I got a little bit lazy and ordered boxes of the dough from Ooni that come in packs of 24 and I store them in the freezer until I need them.
Be nice cooking pizza in the summer with an ooni though so I might consider it.
The main choice you have when it comes to an Ooni is what type of fuel you prefer to use. The options are:
From there, it comes down to size.
- Wood Pellet (Fyra)
- Wood / Charcoal (Karu / Pro)
- Gas (Koda / Karu / Pro) - the latter two need the optional gas burner.
I did look at the wood-burning ones but I figured that despite getting the more authentic 'woody' taste in your bake, I preferred the simplicity of just turning on the gas. Does mean that I can fire it up in all weathers, I've had feet of snow outside my house and the Ooni still had no troubles getting up to temperature!
I would likely get a gas one as have a gas BBQ so makes sense. Thanks
Definitely recommend the Koda in that case! You get a wider flame that goes across the back of the oven rather than two outlets that the gas burners on the others provide (plus you'd have to buy the burner as it's extra on the Karu / Pro)
I've found that ours can get up to temperature in around 10-15 minutes. At around 350-400 degrees you could get a pizza cooked in 60-90 secs
Going to christen my Ooni Koda 16 for tonight's tea. Got a dough ball proving. Can't wait.
How did it go? Let's see some lovely pizza pics.
Good tips, thanks.For a first attempt that is pretty excellently done! Congrats! Those air pockets in your crust are *exactly* what you wanna see.
If you find that it's a bit tricky to launch the pizza off your peel and into the oven, I recommend using Semolina flour to drizzle over your peel before you put the dough down. Should help prevent any stickiness that might create holes. Normal 00 flour is great but Semolina has a bit more coarseness that can help when launching your pizza.
Also, if you can see in advance that you have a hole, you can always fold the pizza over and make a calzone!
