- 15 May 2012
- Louth, lincs
Some arriving this week but there will not be any spare I am afraid, backorders are higher than quantity of stock incoming.
Ok, thanks for letting me know.
OK got my 9900K today and ran a test on my Z370 Maximus X Code motherboard.
Obviously will watch some videos to customise the OC settings a little more and I'll do some more testing in the coming days.
My OCD is twitching at that weird loop kink CPU to mobo line.
Disc. And i had to use it after a fresh windows install on the formula because the wifi and ethernet weren't working.Can anyone tell me if Asus rog xi boards have there drivers on disk or usb? Got one coming and I have no drive :/
Damn, thanks. Think there's an old lappy some where in the house, again only need tinternet, hopefully it still works!Disc. And i had to use it after a fresh install on the formula because the wifi and ethernet weren't working.
I wish I was. Had to dig up an external drive just to get to a state where I would update windows and the rest of the drivers.Are you f'ing kidding?!? I thought all the ROG boards came with it on USB!!!
My cooler is a Corsair H150i Pro 360mm cooler set to the extreme profile, with push-pull fan configuration, Fans are ML120 Pro RGBs (1600rpm PWM).
RAM is 32GB (4x8GB) Corsair Vengeance RGB running at 3000Mhz.
Haven't changed anything from my 8700K OC settings except core from 48 to 49 and voltage from 1.27 to 1.35 (might go lower but didn't have time to test)
On prime 95 version 29.4 build 8 (AVX on I'm guessing) running blend I was getting max temps of 75-80c on the CPU with max power draw of about 200W.
I'm not sure which temps in HWMonitor are VRM but other than CPU the highest temp for any other sensor was 60c. Keep in mind I have A LOT of airflow in my case with exhaust fans runnings directly above the motherboard.
I only ran one Prime95 test at 5.0GHz which was small FFTs at 1.35V and that blue screened almost immediately.
Unless you need AVX, I'd suggest you apply the AVX offset (e.g. minus 3 with 5ghz) and test with prime 95 v26.6.
This will achieve a higher stable OC with lower temps and volts.
Your VRMs will get hammered with AVX.
Same with the Gigabyte Master, no ethernet drivers, had to get them from the site with another PC and USB as windows did not find the basic oneAre you f'ing kidding?!? I thought all the ROG boards came with it on USB!!!
You must have the OEM CPU then, because the retail 9900K comes in that mahoosive blue dodecahedron
