Exactly my thoughts, when i see people on here crying about hardware prices and vowing to become a console gamer. . . Bye Bye! PC gaming is superior in practically every way. Trying to download and update games on a console is enough for me to not go back, certainly for the foreseeable future.
Then you probably didn't read my reply:
Well the Xbox One X already supports Variable Refresh Rate, and it's built in to the HDMI 2.1 spec so yes, they will support variable refresh.
My C9 Oled supports VRR as well.
It's likely that the PS5/Next Xbox will also support 1440p @ 120hz or 4k/60hz
And you are very blinkered if you think that next gen consoles won't run at 4k 60hz. A closed system is going to be much quicker than 'like for like' hardware on a PC which isn't just focused on gaming speed.
To actually reply directly to the points raised by
@String
Q: How much do you think a console capable of 4k60 will cost?
A: No more than £499.99 - Far cheaper than an equivalent PC
Q: Will it support variable refresh?
A: Yes, the next gen consoles will both have VRR, which is part of the HDMI 2.1 spec.
Xbox One X already supports VRR
Q: Can you opt to use it's graphical power for high frame rates at 1440 instead of 4k?
A: This will be very likely,
as you can run the Xbox One at 1440p 120hz
Q: Can you opt for ultra wide instead?
A: Hard to find any information about this, but i'd say it's a possibility on some games on the next gen consoles
Q: Can you pick games up for under £10?
A: Yes.
Q: Can you play all your favourite games from any generation on it?
A: Likely not all, but most
(Xbox has lots of backwards compatible titles)
