So far so good.
running 3840x2160 70hz on desktop, it wasnt very smooth playing gta v set to 70hz but fine at 60hz
I did suffer with the pwm on the philips so had to run it at 100% brightness, currently running this at 45% and its not bothered me yet tho i have had limited usage.
No dead things or hairs in the screen, i had to return 3 of the philips before getting one that was acceptable.
The factory stand seems better on the iiyama.
So it doesn't come with the stand pictured on OCUK?
Could you tell me how good this is for media, TV Shows and movies, Does it run 60hz over HDMI?
It defo does 3840 x 2160 60hz with the included hdmi cable, you have to change a setting in the monitor osd as by default its only 30hz its the same with the display port setting.
Dont use the pc for tv shows or movies just internet and gaming but no real difference from the philips as they are the same panel
Alright thanks, I saw on one of you're pictures there is that a remote that came with the monitor?
Woah, very tempted now with another £50 notes off.Was it £499 yesterday? It's down to £449 today! Going to grab one tomorrow hopefully.
Haha! Do it!!Must. Resist... can't. Afford... argghhhh
So tempting
I would like to run a Amazon Fire TV box (4k) on it, Any idea if the HDMI ports have HDCP 2.2 that's needed for it.
How would you compare the default calibration compared to the Philips?
How would you compare the build quality?
