I can't imagine everyone doing bios updates.
That was a different exploit, Intel haven't had a good run recently.Gigabyte put out a BIOS update for the motherboard in my gaming PC on 1st Dec 2017 with the release note:
Code:Update Intel ME for security vulnerabilities
https://www.gigabyte.com/Motherboard/GA-Z170N-WIFI-rev-10#support-dl
Intel ME is Intel Management Engine
https://en.m.wikipedia.org/wiki/Intel_Management_Engine
Hmmmmm
This is correct from my own testing.I'm not 100% sure on this. But reading a few other sites it appears that Linux can load CPU microcode updates at startup. So if you're running Linux then you may not need a BIOS update to mitigate Spectre.
Windows can do something similar but you still need the microcode so not sure where you get that from?I'm not 100% sure on this. But reading a few other sites it appears that Linux can load CPU microcode updates at startup. So if you're running Linux then you may not need a BIOS update to mitigate Spectre.
Great so nothing is actually fixed, or will be fixed, for the vast majority of consumers.
I was sorting out a new build around the 8700k but I really don't know what to do now.
I find it really hard to believe this level of flaw went unnoticed for so long.
From everything I've read computers will need a BIOS upgrade to counter Spectre type attacks? If so is there any news if Gigabyte will be releasing BIOS updates?
even then I'll be surprised if there is much in the way of timely updates, etc.
