Did you try the Batman game as that seemed to be the most affected by the problem - certainly the speed in which it crashed?
When i had my xxx card i was using xp 32 bit and it replicated the same error - but there is probably an element of truth in what you say with regards to the card not getting fully stressed in your parents system.
Can i just confirm what your temps are under load? This problem isn't a heat related issue and if your temps are well within tolerance under load i would, personally, still be inclined to rma regardless of your parents’ results.
EDIT: You could try your parents card in your system to see if it replicates the same error - if it doesn't you would have more than enough evidence for an rma.
