Had to close bedroom windows as can smell lighter fluid from a BBQ at the back. How can anyone have a BBQ with meat tasting of lighter fluid is beyond me.
Mad isn't it, not used lighter fluid in years. A starter chimney does the trick.
I wonder if a quiet indoor air conditioner exists or if it just a limitation of the technology. I know the answer is to put it outdoors but they still aren't exactly silent and can annoy the neighbours. It's like heat pumps, the noisy bit goes outdoors to annoy everyone else.
How's it going now?
Yeah I thought it wouldn't be as loud as some of the fans I am using (which I consider to be pretty loud) but I was wrong. I would say the loudness is equivalent to running a tumble drier in the same room lol.
Good but noisy. I have decided to turn it off for a bit for now. It got the temp down to 20c after an hour or so, which is good. I think it's one of those that you just use when you absolutely have to, otherwise leaving it on all the time would be annoying, at least for me.
Mine doesn't seem that loud, but I do have a large pedestal fan going constantly in the room so I'm probably used to it, plus I like a bit of white noise as well.
It can make a bit of a noise if the compressor (if that's what it is) switches itself off and on but I just have mine set to max all the time so the compressor stays on.
I suppose the proof of the pudding is whether it helps you get a good night's kip in the heat for a change.
Rather cool outside here today but I've still got the A/C on.
Wasn’t it supposed to be cooling down? Feels hotter than it’s been all week in the North West today.
Yours might be quieter than mine. The db rating on mine said 65db but I reckon it's louder than that. I've had AMD graphics cards that had non aftermarket fan coolers (the ones with exhausts) on them that went as high as that and cpu fan coolers that did similar back in the 2000s, and this seems louder than those, but it might be I'm not used to that amount of noise these days with quieter rigs and components.
Yeah it has been consistently hot in NW all week, and today has been the hottest day so far.
Yes, salad with cold meat, I'd prefer this to BBQ because even though BBQ doesn't heat the house, it heats the body.
It was supposed to be only 23c tomorrow, now it's up to 26c
You lied to me mr weatherman, lied right to my face
If only I could get any salad went to sainsburys and the the shelves are depleted the salad shelf is completely empty and had to go without. Not sure if its the heatwave or something else thats happening at the moment...
