Typing "g4 led dimmable warm white 2w" returns loads of hits.I am looking for some G4 dimmable warm white 2w+ bulbs but can't seem to find any. My Google Fu is weak, clearly. Help!
And when you read those hits most have the word 'non-dimmable'...Typing "g4 led dimmable warm white 2w" returns loads of hits.![]()
Why those instead of more regular GU10 bulb units? ie: Where you can just change the GU10 bulb if/when it fails?Aurora M7 dimmables
Is there such a thing as an inexpensive BC that has colour changing but doesn't require a remote for each individual bulb?
They're up-lighters.Why not change the light fitting, assuming it is a standard ceiling light hanging on flex from a ceiling rose.
Can someone help recommend some 4/5W warm white GU10s?
I'm looking for wider beam angles (wider than the standard 36/38 degrees).
The recommendations seems to be Screwfix, but most of their LAP bulbs are standard angles. I'm looking to do the entire house with about 80 bulbs![]()
diimmable ? but for angle you need to look for smd ones .. if the bulb is genuinely flush with the surface .Can someone help recommend
still looking too - current favourite
Amazon smd gu10 with a much wider 120 beam angle, but once again not small (trial) quantities,
I do not really want 10, but if they buzz or flicker they could go back - don't have a high cri value though, like the philips
LOHAS® Dimmable GU10 6Watt LED Beautiful 4000K
I am still thinking of getting some of these gu10's 5 Watt 110° GU10 SMD LED
however these are not dimmable.
