Anyone using LED bulbs in standard pendant lights?
Hi all,
Just thought i would share my LED bulb story.
In my kitchen i have 2 4 way light fixtures that used to have halogen bulbs in, I recently got an Electricity monitor and to my utter astonishment found that these lights were pulling 480watts :O, I thought "no way hoe-say", Popped to B&Q got 9 GU10 LED bulbs for under £20 installed them and now i have not seen the lights pulling more than 30 watts and they are brighter.
Am gonna go LED bulbs throughout the house especially as the darkness is closing in, Only issue is Bayonet LED's are not as easy to source. Why bother with stupid energy saving bulbs that take ages to get to their full brightness which is still dismal
The end
"I know, cool story bro!"
EDIT: Just seen flasher's post above and thats exactly what my faulty one was doing. Are they replacing yours?
When the first one went i just left it due to cost of sending it back, after the others went and reading your post i decided to take the hit and leave it, was not going to spend any more getting extras.
Had a couple from http://www.ledhut.co.uk/, first thing i noticed was the weight, heavier then the ones from Mrs Wang and the build looks better, twice the price for a reason.
Also had 2 of these http://www.ebay.co.uk/itm/251202551...eName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 from ebay, feel the same weight as the ones from ledhut and so far no problems.
Build just seems so much better on both.
the ones from the ebay seller come on dim then full within a second, both faster than the ones from Mrs Wong.
Eyesight test only, can not tell the difference between the bulbs for spread and brightness.
One difference that i do notice is that the ones from ledhut come on straight away, the ones from the ebay seller come on dim then full within a second, both faster than the ones from Mrs Wong.
Bought a pack of 5 gu10 today, 6w led, I'll report back when they arrive
I bought a couple of the Philips MyAccent 3w LED B22 std bulbs to see what they were like, replaced some 11w energy bulbs in the hall with them and so far they seem great - Tiny bulbs and appear to put out more light - 6w instead of 22w seems a decent saving if the light is better. 2700k so warm, will look at some more or poss slightly brighter bulbs for other fittings around the house!
I need 10 to replace my GU10 Bulbs. My friend got a load from DealExtreme. Does anyone have any recommendations from there?
