I would like to find some LED replacements for my 8 x 75W GU10 63mm bulbs we have in the kitchen. These are £4-5 a pop each anyway and the LED ones I have found are about £11, however I can't seem to find any dimmable ones?
.So what's the best GU10 bulbs?
My Halogens are all 25° beam angle (that's quite narrow/focused I believe from a quick Google), and I've got some fixtures with 35W Halogens and some with 50W halogens. The LED replacements would need to be the same size as the Halogens as the fittings can't take anything longer.
Oh and I don't need dimming at all.
Google found me http://www.simplyled.co.uk/GU10-LED...50-430-Lumens-50-watts-equiv_A11B6Q.aspx?nh=1 which are 60 degree and 410 Lumens, but TBH I know nothing about comparing LEDs!
Shop in Hong Kong, how do you know what you are getting?
Is cree a type or a manufacturer?
I do not want dimmable, but these work fine in no dimmable transformers also do they?
Shame delivery is weeks away.
Where do you see the mtbf figures for those bulbs also, is that on packaging or the web advert?
Ah i see the expandable thingy with the info.
S its is 3*3watt, so twice the energy of the bulbs i bought, the bulbs that are already as bright as i need. Okay.
Might give this place a shot for a few bulbs, amd some other places too, but I liked the very low usage of the ones I bought.
These are one of the best if not the best pound-4-pound dimmables imho
http://www.ebay.co.uk/itm/GU10-MR16...ng_SM&var=&hash=item256ab2e274#ht_5516wt_1164
Bought 10 of them a good few months back and they are working great, nice build quality as well
Because I know what genuine Rotundity Cree led's look like and I took one apart when they arrived
Well it actually draws only 5.5-6.5W to power them, fair enough if they are bright enough, however I would be inclined to chuck a dimmer on and run them <100%!
Not only do you then have the flexability to adjust brightness but the LED's will almost certainly then out-last you as the 100k MTBF is based on them running @ 100% load/heat![]()
What room are they for and which ones did you go for, Cool or Warm?So I came back home and had another look on Ebay, and eventually ordered a 10 pack of Rotundity CREE GU10's for £45 delivered. Have to wait for them to arrive now and see what they're like.![]()
Would they be suitable in halogen sites that are external, under eaves and the front door area of the house?
I figure I might buy a batch of ten, as they seem to be about £34 if it is the same type of bulb, as it is certainly the same seller.
Two colours, i assume warm and clnical as others have described?
Worried that Cool for a kitchen may be too cool, but Warm to soft!
