Is it just me or does anyone else think LED gu10/mr16 are mostly garbage, I just don't think the technology is there yet, Ive had 2 sets of GU10 and 1 set of MR16 (my house is random) some were from ebay some from a proper shop branded makes that felt quality and every time had at least 1 faulty bulb
Bet ive spent £70 now and still not happy, from my experimenting ive found MR16 LED is a waste of time, best off to ditch the transformer and go back to GU10
Anyone else agree with me or have I just been very un-lucky ??
The phillips ones look the part, problem is I have 10x mr16 and 12x gu10 in my house, so that would be £330 for all, bet it would take 10+ years to get my money back
Will do, they're a good find if they are dimmable, just what I'm looking for thanks.
No idea what they're like, getting added to the "next month" rota
http://www.ledsupplies.co.uk/g9-360-36x-smd-5050-5-5-watt-led-bulb-540-lumens.html
These are my favourite fire rated downlighters.
http://www.toolstation.com/shop/p26353
http://www.toolstation.com/shop/p73671
Just put some of these in after your recommendation, look great, simple to install. Very happy with them.
Ummmm I think a table lamp would need a wider angle than what their brightest one provides.
Anyone tried the Philips Master LED Bulb?
