Just put some of these in after your recommendation, look great, simple to install. Very happy with them.
I've got a few of the Philips LED CorePro ones, in Screw (E27) and Bayonet (B22) fittings. Use them in various desk lamps and roof lamps. All non-dimmable, but I think they do a separate dimmable range too.
8W (48W) and 10W (60W) are the same size as each other, but the 13W (75W) is a bit bigger.
For one particular bulb I'd like to get something brighter than the 1055 lumens of the 13W (75W)... but the 20W (100W) 1521 lumens bulb costs £40!
What do you need 1500 lumens for
Did you change to LED?
Trying to persuade the light to bend round a corner
Also to note on some of the cheap Chinese GU10, be careful. Don't buy any without a glass front they can be extremely dangerous. The glass ones are ok as there is no live part to touch even if it uses a mains dropper inside. Some of the other cheapo ones use a mains dropper and have touchable solder points where the LEDs are surface mounted!
Not yet mate, just got the standard bulbs in for the minute.
I presume they can be changed to LED?
Yes they can, but you need to be careful in you choice of GU10 LED lamp, as some have a more pronounced lip around the front of the lamp, than a standard GU10 halogen lamp making fitting impossible.
I am order some various GU10 lamps this week to try in same fittings.
