- 3 Nov 2004
- UK
Couple of things, you're under-loading the transformer and they don't output clean 12v. It's not a complicated circuit for Halgons, which are just big resistive loads with a high initial transient current. The LED's may pull below the minimum working load for the transformer and the output may be not a clean regulated 12v. It best to use transformers/driver designed for the application, and you might find running the old tx out of spec causes local rf interference.I am having some issues with some flickering LED lights and some that come on for a few seconds and then turn off.
Somebody pointed me to this: http://www.lightbulbs-direct.com/article/replacing-12v-halogen-mr16s-with-leds/
Can anyone actually explain what the maths for working out whether an LED will work in my transformer or not because it doesn't make a lot of sense to me.
Example 1 - I assume that is 5x12 = 60VA....but example 2 I dont have a clue.
