I went through so many cable strippers before finding a decent one for CAT6. In the end the best one turned out to be some freebie naff looking bit of plastic that came free with a crimp tool.
Usually use 1.5mm twin & earth as mentioned above, from the downlighter to a junction box, usually Hager J501 junction box feeding say three or four fittings, or sometimes 0.75mm 3 Core( 6amps) ample rated flex,from fittings or occasionally 1.0mm 3 Core (10amps) again back to a Hager J501's, all depends on the access available.
It's impossible to get get more than one cable under the cable grip on the light fitting.
If using flex I pre-wire with a 400mm or so length all the fittings first, then a simple jobbing of connecting to junction box/ boxes.
EDIT: I always prefer to use the Prysmian Twin & Earth Cable from Screwfix compared to Toolstation cable.
http://www.screwfix.com/p/prysmian-6242y-twin-earth-cable-1-5mm-x-50m-grey/51381
http://www.ebay.co.uk/itm/111148647564?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Ordered 4 of them.
These junction boxes, i'll be able to wire in at least 4?
After my last post about cheapo ebay LED's I got my hand in my pocket and ordered 17x branded LED's from a reputable lighting shop, I went for 4 watt GU10, and took out my old transformers so now all my lights are 230v (was 12v mr16 before)
I cant believe the difference the light is pure brilliant white, I thought the 4 watts wouldn't be enough for my bedroom and kitchen, I couldn't of been anymore wrong, if anything there a tad too bright!
I've reduced my load from nearly 1kw to less then 70 watts , and now have more light!
I just need to order another 11 now for my other rooms![]()
Put them on a trailing edge dimmer, the Varilight V-Pro being among the best, & availble in various finishes.
http://www.ledbulbs.co.uk/products/...)/4085457481?gclid=CM_Zx6z22LwCFazHtAodAzUAlw
P:S: Order led lamps through Quidco, can get cashback, voucher code etc
I'm trying to plan the positioning of my down-lighters but was finding it difficult to imagine so decided to visualise it. I've drawn a to-scale image of the longest wall in my bedroom (419cm) and tried to layout the lights as best I could. Distances are from the centre of the lights. The height is also to scale (8ft).
1px = 1cm
Any suggestions?
o o o o
o o o o
o o o o
o o o o
o o o o o
o o o o
Interested to know what you mean by "choice of colour temperatures"? Is that before or after purchase?
That makes perfect sense thanks.
I just wanted to get an idea of what the most "ideal" distances would be. I'll try to map them onto my bedroom ceiling next and check for beam obstructions using a stud detector (hope that works).
Is a grid pattern like the one below best:
Code:o o o o o o o o o o o o
or an offset pattern:
Code:o o o o o o o o o o o o o
o o o
o o o
I was going to do 12 downlights in my 12.4m2 bedroom. If it turns out to be overlit, I could set the max brightness level lower.
From experience I think it depends a lot on the bulbs you use.
Is yours like this then?
Code:o o o o o o
o o o .
o o o
I always prefer to use a grid layout, looks uniform & balanced, also prefer to use a even number of fittings.
But, there are occasions, when you can tweak the layout for one odd lamp, say when you have a alcove, or recess to light.
Black Dynamite: Take 1 downlight for every 1m2 is optimal, worked with a 50w halogen lamp, but it's gone out the window with the LED lamp in my opinion with the various wattage available now in led lamps.
Code:o o o o o o
I knew i'd read it somewherecan understand why with LED lamps it isn't essential. I'm still using the 50w halogen bulbs and it lights my room fine, so with LED's the light would be perfect.
Just want to point out that this is the first set of downlights i've ever installed and one of the first bits of lighting work i've carried out so apart from the layout i'm pretty much uselessNightglow is the expert, his recommendations and advice really helped me before I started posting on this thread!
