Ok looks complicated but im sure it will be easy enough after some research, i wonder though if there is a free method to use as a Pgenerator... for instance, i wonder if i could use a Laptop instead of a RasperyPi for instance im pritty sure you can boot rasperypi iso`s on windows or linux and then get calman to connect to the pi generator over lan or wifi to my laptop for the pgenerator.....
going to do more research on this lol any idea`s is it possible ? cause i really dont want to have to pay more money £130 ish pounds for the rasperypi 4b kit ....
Ok did more research and yes think im going to need a rasperypi cause the thing has to connect to tv with hdrmi and i dont have a laptop that has 4k over hdmi apart from my pc....
then again im just wondering if its also possible to run the rasberrypi pgenerator through a vm from my main pc thats connected to my tv with my 3090ti
that would probably work but i need to find out if i can emulate a rasberry on a pc lol
EDIT2: ok vmware workstation should be able to run the rasberrypi pgenerator image iso and mirror it as a rasberrypi from within windows
going to give this a try tommorow
then once up and running i should be able to connect to it with calman home for lg as it will be on the same network
ok i think this might work but in all honesty im not holding my breath lol
EDIT3: ok its impossible lol, the Pgenerator Iso seems to be some form of linux but the linux distro that im using cant seem to detect what format its using properly so i cant load the iso in rasberypi cause vmware cant figure out how to load the iso from the sdcard lol
