Thank you for the reply!4090 and i have calibrated my tv
Do you think i could try for a replacement?
... Press a button once every 4 hours? It's not distressingIs it just me or does the TV want to turn off after x amount of hours (comes up with something along the lines of press an input or the tv is turning off . . . . ). I have turned the 4 hour auto turn off in the settings yet this does pop up randomly.
Anyone have a suggestion besides get outside more![]()
Folks.. watching some movies on disneyplus, I notice juddering in some scenes. I guess this is probably to do with no trumotion being turned on?
I was told that you cant turn this on from a PC input? Is there anyway round this?
Smartarse
(Actually yes I was thinking that but then I was also thinking about other video sources that I would plan natively on my PC, e.g. youtube and content on PC?).
Sorry I should have made my question clearer!
Why do we have to press the power button twice to switch off the TV? I'm not sure why but it really annoys me
Hmm doesnt seem to work bud. Doesnt the juddering bother you?I think you just need to switch off the game optimizer. A pain.
I think he means the TV itself than the remote? I have to pay press twice also I believe on the TV.That's odd. Only have to press once here.
No I mean the remote. I press the power button once and then it goes to like a screen saver with language options and then I have to press it again for the TV to actually switch offReally? Simple as that?
Oh right sorry for my assumption! Im sure there must be a setting in General settings somewhere. I only have to press it once on the remote as well.No I mean the remote. I press the power button once and then it goes to like a screen saver with language options and then I have to press it again for the TV to actually switch off
Is that from the moment you started using it?Oh right sorry for my assumption! Im sure there must be a setting in General settings somewhere. I only have to press it once on the remote as well.
Ok so I've had another look and when I press the power button on the remote it goes to a music menu where I can download music, choose a Bluetooth device or play music from a flash drive....I will be completely honest bud, I believe so. From the moment I started using it.
I THINK there is a feature called Always Ready.... is that on for you? if so turn it off and see what it does.
Ok I've found it! It was a feature called "always ready". I've enabled the feature that still has it active but disabled the wallpaper.Ok so I've had another look and when I press the power button on the remote it goes to a music menu where I can download music, choose a Bluetooth device or play music from a flash drive....
Any ideas?
