I switched to sdr and used the settings recommended and I do think the white brightness is better (in hdr it looked a bit greyish) - I like a bright screen.Just enable HDR for content that is HDR. That would be my recommendation
I Love big monitors - I still remember when I got one of the first big monitors that ever came out it ... think it was a dell 2407 oh big 24" widescreen. Cost over a grand back then. I got one of the first chinese knock off of the philips 40" monitors (wife actually uses it now for her work) - and I had been using the philips in my sig for is it 4 years now~? (really nice monitor). This 42inch c2 is actually 1 inch smaller then my philips so im actually a bit concerned its too small. But like the screen a lot so keeping it. The screen reminds me of my old catleap monitor (no or very little screen coating which in essence was a glossy screen (and probably the best glossy screen you could get ... ever.) But it has a dvi connection and it seems only old cards have those (so can run it off my old 970gtx) ...I returned my 42 C2 in the end. The screen was amazingly good, never used anything like it. In the end, with my 60cm depth desk, it was just too big for both gaming and productivity. I have gone back to a 34" ultrawide LG IPS which is ideal for work, but I do miss the fantastic screen quality of the C2.
i've been reading up on this more this week, and watching the "classy tech calibrations" video. While the actual method for doing a 2 point calibration manually seems straight forward enough, i have a load of open questions that it seems hard to find answers for! So much conflicting info scattered all over the place. i dont know if you've seen answers to any of this?I have been slowly reading the last 200-300 pages of that mega thread past few months, I think that HDR/DV colour issue might have started around 2020 actually not just just 2022 LG TVs with LG Calman, so that is why someone referred to autocal in hdr as a lottery. It was Miguels post 2 weeks ago that openly said in plain english Autocal HDR is a waste of time I understood that english part
This is dark-007s post last week and again his April 2021 post, you can see even under that last post Wifi-spy/Tyler was still around posting but I don't think he addressed this bug or colour inaccuracy issue but even below that people are playing games and films and spotting the colour issue.
Even Connecteddd has mentioned his own software has issues with HDR calibration so was mentioning manual or 2 point method. And I believe people still had the same issue when using external patterns via that Rasperberry set up so went 2 point/manual way.
d-mans post to Miguels who done a 2 point calibration also here confirming his 2 point is correct to his own calibrated TVs at home, also Keepitclassytech who shows he does the 2 point in his C1 calibration video, if you read the YT comments 1st post by Dario P and the 5 other replies even Ninjacian TV calibrator also does the 2 point.
I think its a blink and miss it thing like Miguel mentioned in his post so perhaps most people that ran autocal for HDR/DV do not see the incorrect colour issue unless they compare it to another uncalibrated picture mode or correctly calibrated TV or just OOTB TV. But surely 3-4 calibrators and the biggest community are right here. It does not sound like LG and Calman can fix it also since its been this long of an issue, but maybe you might be able ask PD about it?
- The detailed explanations and technical detail from Ted in the links above were back from 2020, i have no idea if things have improved since with newer TV's, firmware, Calman software. they've had some pretty major updates to their colour engine since for instance
- some people are suggesting that the 1D LUT is fine in AutoCal, and it's the 3D LUT (Matrix LUT) that is the supposed problem, yet if you follow the 2 point manual process as per that video, that's only really adjusting the 1D LUT /colour temp part. which is apparently, the bit thats ok?!
- If it is the Matrix LUT that's the problem, that step doesn't apply to DV calibration, so why are some people using this method for DV instead of AutoCal?
- Have you seen any explanation for how a user would even establish they had a problem with AutoCal in the first place? i see comments like "it's a lottery", but whats that based on? what are the symptons? what are some decent tests to see if you have an issue? I've never experienced any noticable problems with HDR or DV AutoCal on my LG CX, or C2.
- Any idea why in the Classy Tech Calibrations video he sets a custom white point with coordinates of 0.3107 and 0.322 instead of selecting D65?!
Just found the final piece for this as if you did fulscreen it still stretched, you have to go to the Nvidia control panel and change the scaling option to no scaling, keep the scaling set to display, that way it's all handled by the TV.Hi not sure if resolved but I noticed in the new update it tells you the resolution the game needs to run at, any higher and it goes full screen 16:9 3840x2160, 21:9 3840x1600 and 32:9 3840x1080. You can run a game fullscreen at these resolutions. I use the 21:9 for racing and flying but not strategy games. It would be great to be able to have a hot key to change this or customise the game optimise menu to haveit there, you can edit it but not put all options there just what LG provide![]()
Super quick and easy and the test afterwards showed less than 0.5 delta in the colours so leaving it at that. I'll do DV at some point as well.
Went back to redo the sdr properly again as I wanted to do the dark details extra option this time round. had a nightmare. The autocal kept throwing up stupid results all over the shop. Took me about 5 goes before I got sensible figures again. So wont be doing sdr autocal in a hurry again!
never got round to doing the rest after doing SDR and HDR so never touched the filmmaker modes sorry.
Happy enough for the moment since I use my screen exclusively for the PC.
2 point calibration on HDR was easy and went without a hitch following the video guide.
From memory i did both D65 and the custom one in the other video. Personally I couldn't see any difference much so personal choice I suppose.
HDR 2 point took way less time to do than the sdr autocal and worked everytime so didnt bother me to keep trying different things. Like you on the SDR, I spent hours so once I got a good result and nothing had gone wrong, I left it at that.
Not heard of that before but long term it probably doesn’t have much value as the panel will age and drift and you’d need to run the calibration again really. For short term accidental resets or something it could be useful thoughahh good to hear, I am also trying to figure out a tool not sure you or @Baddass are aware of it its called bscpylgtv it has the option to back up your SDR & HDR calibrations and restore them but I have yet to figure out the proper command lines to do it properly, it uses that old school DOS type commands or CLI linux type commands.
If anyone figures it out should save all valuable time in future in case we mess up the TV![]()
Not heard of that before but long term it probably doesn’t have much value as the panel will age and drift and you’d need to run the calibration again really. For short term accidental resets or something it could be useful though![]()
Which would be a major shame for those wanting to use them for Pc useG3 is looking impressive with the MLA tech
but not on the C3 series and I think its not possible to put MLA tech on 42 and 48" due to size of pixels sadly.
hdtvtest recently mentioned they may have removed the TPC and GSR feature on the G3/C3 from the service menu since he saw no option on his pre model, maybe
LG ditched it finally.
I watched that earlier, haven't LG now fixed the auto dimming on the c3? He demonstrates it in that video. If so you wouldn't need access to service menu anyway, I assume.Its disappointing for new G3/C3 owners for sure, it also effects just regular home TV users watching TV shows, movies that auto dimming algorithm is so hit and miss so sometimes scenes just go pitch black I guess they can't account to track dark scenes for every new tv series/movie that pops up every minute.
Lots of people over on AVF/AVS community are looking at the C2/G2 again. hdtv has released a new video since everyone moaned its a review unit not retail unit so he should not have shown tpc can't be defeated, but in vincent fashion he has corrected them and confirmed its not available on his retail 42C3 unit and G3 unit.
Be nice if they did that for c2 also
