Exactly what R3X said. Costco are second to none on this.Should be fine, 90 day returns are the best going in any retailer.
Very good points, thanks for this. I guess it will be case by case based on usage/environment etc.For my use case on a c9 which I'd imagine may still apply here, auto dimming isn't an issue on windows desktop.
I find it becomes a nuisance when I have hdr enabled during desktop use, but is a non issue because I only use sdr on the desktop. Even at low nits, the screen will dim over time with static content with hdr enabled.
I use the screen in a dimly lit room, which means I use around 100-120 nit brightness. If I were to double the brightness, the dimming over time would kick in and become a nuisance.
Depending on use case, the auto dimming on the desktop can range from being non-existent to being an issue. From my camp, if you set 100-120 nit brightness, and use sdr for the desktop, it won't be an issue.
Great video. That guy from HDTVTest is so informative and clear.
So in a nutshell get the remote, turn off TPC. Job done?
Whabout all the other videos above talking about disabling other features related to auto dimming?
On another note, I read reports that if you are less than 32" away from the screen its too big.... what are your thoughts?
Have you been able to confirm manufacture date or panel?![]()
Well, I did it lol (excuse the messy desk!)
Richer Sounds price matched Costco and there’s 2 weeks price protection which should cover any Black Friday sale price drops too
Honestly no idea - if you let me know how to check I would be happy to though!Have you been able to confirm manufacture date or panel?
I've pulled the trigger with RS hoping for a WBE nervous as the guy in store didn't know there were newer panels after Q2 when I called.
You threw the box outHonestly no idea - if you let me know how to check I would be happy to though!
edit: Box has already gone to the tip so can't check that![]()
You threw the box outI still have my seven year old Bravia box lol
Manufacture date is the easiest that's on the label on the back bottom left under the serial No, I know some from May onwards were newer WBE
There is a Reddit page that has info on the instart link accessed via the web browser to find out info without the LG service remote not sure if I can post the link?
In the service menu of the C2 42-inch, find "Module Info 2" and the panel type will be one of the following:
WBC (old panel) = 00/00/1/03
WBE (new panel) = 08/00/1/03
Good to know this will keep an eye out when I go to collect it.I bought from JL solihull last sunday and it is WBE, also says SELF LIT OLED evo on the box in big letters.
Sounds like it's worth a trial run then!Exactly what R3X said. Costco are second to none on this.
Not even a year. It's the early adopters tax!I cant get my head round that this panel was nearly double in price... what... a year ago?
Is that the margin LG and the middle men have been enjoying? Crazy
Looks like Sept 2022 if that helps. I'm a hoarder too but wife said it had to go straight away lolYou threw the box outI still have my seven year old Bravia box lol
the one from the LG remote? it auto hides after a short period, but a wiggle of the remote brings it back upAnybody had an issue with losing the pointer on the screen? Anything that can be done to help stop this?
