No sorry not the magic remote pointer. My mouse pointer in Windows 11 disappears!the one from the LG remote? it auto hides after a short period, but a wiggle of the remote brings it back up![]()
Pretty sure all new ones now will be the new panel?Is there a way of checking the model info on the C2 evo 42" to confirm its using the WBE panel instead of the older WBC?
Thanks I just checked using the software, WBE panel here too...phew. Mine was delivered from JL in Solihull tooI bought from JL solihull last sunday and it is WBE, also says SELF LIT OLED evo on the box in big letters.
Must be a windows setting then, nothing to do with the TvNo sorry not the magic remote pointer. My mouse pointer in Windows 11 disappears!
It's weird how my tv isn't picking it up, just checked. Seems like a very minor update at least.There was an update rolled out today, so worth checking.
Except for people using it as a monitor, thinking about burn in..it may actually be a meaningful differenceAll new models should be the WBE panel not that it makes any meaningful difference on the 42” and 48” C2 models which do not feature the brightness booster anyway. In fact the WBC could arguably be considered better in some areas as the WBE panel has a pinker tint from off angles. But really it makes no difference, people shouldn’t worry about it![]()
Ah, it's windows 11 onlyNot sure if this has been posted but a new HDR calibration app is out for Windows and actually works surprisingly well , made a noticeable difference on my 77 CX after running it
The Windows HDR Calibration app is here - DirectX Developer Blog
The wait for the Windows HDR Calibration app is over! If you're on Windows 11 and want to calibrate your HDR-capable device, you can now go to the Microsoft Store and download the app.devblogs.microsoft.com
Yeah needs to be Windows 11 but personally not had any issue with it at all , easily as stable as windows 10Ah, it's windows 11 only
My PC is too old atmYeah needs to be Windows 11 but personally not had any issue with it at all , easily as stable as windows 10![]()
Except for people using it as a monitor, thinking about burn in..it may actually be a meaningful difference![]()
Enjoying the size so far, quite a lot of text fringing when doing work from home stuff, but can live with it. With games and movies it's incredible, except 1080p content now looks a bit crap![]()
on C2 it always remains 2k
if I try C1 again I can put the 4k at 120hz but with the limitations
for now I play in 2k, I would not want Oled C2 to have any kind of problem
Yeah most youtube looks a bit **** now hahaYeah not much you can do with low 1080p content, the VA and IPS TVs and monitors really hide the flaws well in older HD content. But I reckon the 1080p higher quality stuff and 4K excels on all OLEDs much better.
I was watching Orville on the C2 yesterday and it looked 4K HDR, but it was just an 1080p non HDR source.
Also your OLED picture quality will adjust, id say 100-150 hours it should mellow out but even 200-300 hours things get better.
