Caporegime
- 18 Oct 2002
Thanks guys, seems like the new cable has solved my issues with the 6800XT (bar one, it's liveable with!). Thanks
It will work with a 3.5mm to 3.5mm cable, you can get them for 2-3 quid of flebay
Just have to connect to Line in (usually blue connector on back of pc) and just enable/tick line in on your soundcard properties. Also adjust your CX sound setting to audio out mode rather then tv speaker.
Just bare in mind it introduces a nasty hiss when you do this so if you are listening to music or really want the best sound quality you need to use the optical audio out on the CX instead, but you then need optical input (tosh link) on your soundcard or suitable amp, headphone amp/dac etc
The hiss drove me mad so got a dedicated headphone amp with optical input to do this they cost £30-150+ though, I think you can get cheaper units of flebay for 20-30 quid with optical input its like a usb soundcard.
maximum 10% better performance for 2x price of the 3080 is a NOT a good deal whichever way you look at it.in 2 years time IF most games demand more than 10GB (unlikely) they will also demand faster, more advances GPUs,and 3090 won’t cut it anyway. 3080 FE is the best.
The 3090 has more CUDA cores, more ray tracing cores, more than double the GDDR6X VRAM, a wider memory bus and memory bandwidth, and a slightly higher memory clock then 3080 so if you buy 2x 3080 that's still only 20gb Vram compare to 24gb and Nvidia made a announcement on January 1, 2021, ends SLI support. With RTX on you burn more Vram so what's the point if you have to turn off RTX on a game that supports it limited by ram.
end result is still twice the price of 3080 for just 11-12% better performance..The 3090 has more CUDA cores, more ray tracing cores, more than double the GDDR6X VRAM, a wider memory bus and memory bandwidth, and a slightly higher memory clock then 3080 so if you buy 2x 3080 that's still only 20gb Vram compare to 24gb and Nvidia made a announcement on January 1, 2021, ends SLI support. With RTX on you burn more Vram so what's the point if you have to turn off RTX on a game that supports it limited by ram.
only gaming side is being discussed here..totally agree on all your points, I don’t understand why people don’t get this , the 3090 is so much more than just gaming
for this minimally improved performance it should cost around 20% more than 3080 not twice more. most the money spent on it is wasted (for gaming) if 3080 is not good enough,maybe better wait for next gen cards,instead of paying 2x for such minimal performance improvements.
It will be amazing if they make smaller than 40” OLED..the reality is 48 is really not meant to be used on a desk. I don’t buy LG’s manufacturing difficulty excuse for smaller sizes and think it’s mainly a strategic decision. maybe they know the market for a smaller (and yet pricey) screen is niche and they can’t sell as many as larger 55”+ sizes..
Didn't you say you own a RTX3080!With a 3090 I'd get 65 FPS instead...
The LG 48CX was design to be a desk TV/monitor. so don't understand your point of view but some members like me have hop for bigger screens to game on 55/65/77inch on this CX owners threadAn OLED is top of the range it delivers excellent picture quality also superior 4k compare to a pc monitors. The highest number of dimming zones you’ll get on a high end LCD/QLED with FALD is about 600. A long way short of the 8 million completely independently dimmable pixels an OLED has
You mean phones,tablets you own not the same as an OLED TV because you said you own a QLED TVlike I said I’m big fan of OLED screens and owned many OLED devices,
you are saying you don’t understand my point about size? which is really strange because it’s all over this exact forum,Reddit,youtube etc since it’s a valid point.
Another YouTube idiot TheTechChap that desk is so, so small no wonder he got an headache from a 48cx sitting that close and then he makes a rant about the reflections on the screen if he did his homework on OLED it's a glossy screen so it's going to pick up the window light behind him, people like him have no common sense
His main purpose was advisement the monitor he was using and he must have seen the OLED have a glossy screen when he took out of the box. Like I said another YouTube rant idiotHe seems happy as Larry with it initially as well then almost comes up with reasons to get rid of it, as you say one being his own desk which is easily solved and using reflections as another excuse.
You mean phones,tablets you own not the same as an OLED TV because you said you own a QLED TV again not the same as OLED TV.
If you want to listen to rants posted on other forums that's your choice this is a CX owner Thread and most members here have done their homework only you question the 48CX is not desktop use but you don't own one! I use a 55CX for desktop gaming so you think 48inch is too big!
Maybe you will find more rants about it on Reddit, OLED is glossy screen best to stick with your QLED TVIMO
Advertising a niche £1500 monitor that is sold-out and out of stock every where?His main purpose was advisement the monitor he was using and he must have seen the OLED have a glossy screen when he took out of the box. Like I said another YouTube rant idiot![]()
Yep, I first tried it on a 60cm desk and for me games were unplayable but changed the desk to a 90cm and its perfect for meYup you need a nice deep desk with it for sure, my nose is 75cm away from it (aligned with the exact centre, maybe slightly above) and I wouldn't like it to be any closer!
