ABL - I had my OLED brightness set to 80 or 85, pushed it down to 60 but that made no difference other than the screen not being as bright.
So since 1836p worked for me and I kept forgetting to to switch the screen back to UHD, I wondered how I would go about automating things, possibly scripting.
WoW runs in fullscreen windowed borderless, there sadly is no automatic switching. With other games in fullscreen, you can just pick that resolution and go with it.
1800p is middle ground between 1440p and 4K fairly often used by consoles it upscales to 1800p, which isn't 4k it's an upscale. Compare to native 4K output. If you lower the OLED light to 50/30 the ABL isn't turn on much as a 80/85 setting.
I believe game presets are new, standard, FPS, RPG and RTS. Truthfully, they all look like crap except for standard. Boost may be new.
But there's no big leap in image quality over the C1 compare to CX, if this was your first OLED the C1 is for you but not from CX, imo CX 4K with VRR 5.9ms input lag 4K @120hz, 6.7 compare to C1 4K with VRR 5.8ms, 4K @120hz - 5.2ms input lag. If you think you can see the 0.1ms/1.5ms difference then your eyes are better then mine, C1 will improve the upscaling further and deliver more accurate colours but as you know native 4K is better then upscale it contains more detail, using upscaling detail cannot be added. The C1 webOS 6.0 looks nice I'm sure they could do the same for the CX but they won't the chip Alpha9 came out in 2018 and in 2019 Alpha9 Gen2 will support next-generation high frame rate (HFR) content up to 120 frames per second so the (HFR) isn't new.
. They had a 10% off promotion when I bought for around £1150 (that's with a £40 voucher). Now I can see why.
