- 14 Feb 2012
What are the other 3d options for (side by side, top/bottom and the other one I cant explain!)?
Side by Side ? have a look at this LG demo in normal mode - that will be easier than trying to explain. http://www.youtube.com/watch?v=bTEPm5ZUcXU&feature=related
To experience in 3D - Make it "1080p HD" quality and Play it "Full Screen".
Use the 3D button on remote and choose SBS (side by side) to view in 3D.
SBS is the most common format out there.
Top/bottom - commonly known as OU (Over Under) is similar except the image is split Over and Under in the same frame rather than SBS.
Those 2 cover the 99.99999% of content 'out there'
The other 2 you probaby wont find content for (unless its test content)but some Hardware and Software will output 3D in this format (and you normally select these formats from the source output and not on the Monitor)
Checkerboard - same thing except the 2 images are split in a checkerboard pattern.
Interleaved - Same thing again except the 2 images are split into horizontal lines. ("Line Interleaved" is what you would choose for output from PowerDVD ultra for instance)
