- 22 Jul 2004
Rinsing is all well and good, but experience has taught me that you also need a water pump to create turbulence within the radiator to force the debris out, otherwise some is bound to get trapped during a basic rinse. It needs to be a D5 pump or something of equivalent power at full blast, too, and you also want to use filters to catch the stuff going round the loop, or you'll be using a lot of distilled water.Yes all new blocks, I followed a video on youtube describing how to flush and rinse rads prior to use. Even though the PE rads said on the box that flushing wasn't required and there was very little that came out of them there were some particulates so it was worth doing. I read up on this for a long time while planning my build, it’s apparent that there are many opinions on what and what not to do, often contradictory which doesn’t help someone new to water cooling. To be fair this is only a minor problem that I can resolve, I’m still pretty chuffed to have successfully built my first water cooled pc with a disto block and acrylic tubing, which is running very cool and quiet, albeit not looking quite as white as I’d hoped.
Rinsed to hell and back, but there is clearly something driving a reaction here, I can only imagine its at homeopathy concentration levels But in all reality its likely to be the pH that's out of range.
I'm really annoyed by this to be honest given i followed all the directions, used Distilled not De-ionised water, flushed and rinsed everything according to directions and then rinsed some more, I'm a scientist by trade so picky about how such things are done
