What 'rest'? It was all 100% true!Thanks for answering the question but do you really need to add the rest?![]()
You can read it in the regulations here: VOSA
Go read rule 7.1 if the car was fitted one, it must be physically present in the MOT. As other's have suggested; you just keep a cat in your garage for special occasions.
Rule 7.1 on Method of Inspection, "On vehicles that qualify for a full cat emissions test, check the presence of the catalytic converter"
My 306 has a Particle Filter, Not a Cat. Infact it now has nothing.. as I cut it out and replaced it with a straight pipe.
I have no Garage special
So does it pass or fail? Apparantly Diesels don't have Full Cat Emissions Tests.
3.
A catalytic converter missing where one was fitted as standard
[TW]Fox;20618849 said:So are we now saying that 100% of the points Biggles made in his opening post are false?
If you did have a cat:
The reason for rejection is very clear, the method of inspection if carried out to the letter will miss the decat.![]()
On vehicles that qualify for a full cat emissions test, check the presence of the catalytic converter.
Stop being an arse.
Oh what fun, more customers moaning about things THEY think shouldn't fail.
My 1995 Eunos (Import) was put through a non-cat test despite having one fitted, so I assume this will still apply and I can de-cat away? I'll be making it swappable anyway.
Aww, I was hoping all HIDs required washers and levellers so we could get rid of the chavs that drive round with their horrendous beam pattern blinding and dazzling everybody![]()
Cos that will fix the fact the're not in projector units?![]()
If their taken off the road due to the washer/leveller thing then it probably would.
[TW]Fox;20621177 said:Which they won't be.
[TW]Fox;20618909 said:If the vehicle doesnt qualify for a full cat emissions test there is no check for the presence of said cat.
