I find it doubtful a little excessive lube is going to cause fans to seize. I imagine in that case the fan was actually faulty.
It's just a little bit of oil which is easily wiped up and no more effort than dusting your pc.
I'm really not seeing the problem tbh.![]()
Just saying if I noticed a bit of oil leakage I would just wipe it up if all is ok.
Its not excessive, fluid dynamic bearing fans should not leak at all by design.
Edit: Bit of Google research suggests the fans used on MSI GTX and MSi AMD R range cards are manufactured/supplied by Powercolor.
I have a Powercolor PCS+ 7870XT MYST. 8 Months old. i game with it daily, PC is on 16 Hours a day.
Can you clarify who rejected the seized fan RMA upon inspection, OcUK or MSi?
Why can the excess oil not just be wiped up ? It's not uncommon for bearings to be over lubbed during manufacture. It's mineral oil so is non conductive and no risk to your pc.
Am I missing something ?
Sent in my card via DSR yesterday, arrived today and refunded hours later, can't complain.
It's unfortunate though, I liked the card, the cooler's nice but I can't just ignore the oil issue.
Did OcUK refund you for the oil leak? They've just sent mine back saying the oil leak isn't classed as a fault.
Ninja Edit ^![]()
Can you please make a post in the customer service forum so I can look into this please. With your order number and all the details. Thanks.
Will get on it in the morning.
