My RMA arrives tomorrow. For those interested, a new batch arrived today, spoke to a different person, Sarah, returned my call and sorted it out straight away, much much better than last weeks nightmare, fingers crossed it's a good one.
easyrider said:I'm looking at this screen to buy
shall I?
Dup said:The general consensus is that despite a few teething problems with a few units, the product without fault is a fantastic peice of kit. The question you have to ask yourself is will it fullfill what you need it for?
I'm ordering mine tomorrow. Does it come with a DVI cable? Also, what is the preffered method of RMA, OCUK or NEC, in case after 4 or so days my unit has any irregularities.
cheers
easyrider said:why do they let them go out when they have bleed?
whats happens if i oder one and its got bleed?
do i send it basck to ocuk or nec direct?
Gibbo said:NEC should look after you just fine and will courier a replacement to your door normally within 24-48 hours so quick and no expense to you. Obviously OcUK would look after you too, so you can choose either way but NEC is recommended especially now they are aware of this issue.
spluff said:arcane - what problems did u mention that u had with your monitor?
Dup said:do they have a DVI cable supplied?
crayz-walz said:Were do you contact , to report my monitor for an rma, i can't find anything in the info i got with the monitor, nore can i find anythingon the site, the number i rang for nec just gave me a dead line, i have back light bleed. and dead pixels. (grey ones) . what do i need to do . plz help . i dont want to get stuck with a monitor thats going to but me With them little grey dots stairing at me .
craig,
Gibbo said:Adam Gay
