tweakinfreak said:
can someone advise the best way to clean the screen on these monitor, last thing I want to do is scratch it...
You have to be careful with the specially coated screens, including AR and OptiClear. If you don't have problematic smears any super-fine-micro-fibre cloth will do the job nicely (just to lift the dust). Slightly moistened in case of smears. DON'T use standard lint free cloths, towels, cheap screen wipes, papers ...etc as they are no go for this type of the screen (and probably not for any). Also, DON'T apply the above-normal pressure on the panel itself, as it may cause the side effects. If you want ready-made product, someone on this forum recommended KlearScreen some time ago. I personally tried this product, and it's very good. You need Klear Screen "High Performance" or "Deluxe" Screen Cleaning Kit. According to the spec, they are also optimised for the Glossy Screens. I'm using it for my camera, notebook, LCD TV, LCD monitor ... virtually everything.
If you use any chemical solution, here are the steps:
1. Turn off your monitor
2. Lightly mist the screen with one to two pumps of the spray fluid. (one pump for screens 14 inches and smaller; two or more pumps for larger screens)
3. Using a soft corners of the microfibre cloth, spread the fluid evenly around the screen in straight lines, side to side, top to bottom.
4. Using the dry portion of the cloth, polish in straight lines, side to side, top to bottom.
5. If cleaner is still visible on screen (you have cleaner smears and this is usually exposed when cleaning the glossy panel coating) you should repeat the process using less cleaner and polish again with the cloth.
Apart from other things, specially formulated fluid (like KlearScreen) is sometimes better because it can make your panel coating "antistatic". In other words, your panel will attract less dust. If you don't want to bother with chemical solutions, just buy some superfine microfibre cloth in the supermarket near you. Use it dry for the dust lift off or slightly moistened for the smears. If you need to moisten the cloth, I would recommend the distilled water as the normal "hard" water from the tap can sometimes introduce the newly developed smears.
