Threadripper vs i9-7900X gaming comparison.
http://www.tomshardware.co.uk/amd-ryzen-threadripper-1950x-game-performance,review-34018.html
Give and take, little in it.
Thanks, which brand is best for reliability?Synthetic benchmarks i.e. read and write speeds won't make any difference in games. Will be the same. Reliability and price would be my consideration.
Good Q, taking in a lot of data in a short amount of time makes me do these kinds of mistakes. I need to compare prices.samsung or crucial
samsung 960 evo or sm961 nvme m.2 if you have the money and m.2 slot
samsung 850 evo or crucial mx500 sata3 on a budget
why not get 1x 1tb ssd instead?
I sitll dont quite understand, hahah, I need to do some more research on that.nvme = pci express
m.2 is the form factor
Thanks for your input.The best brands IMO are Asus and Asrock, MSI have always been at the back of the pile for me. If I was buying it'd be the Asrock Taichi over everything, I'd rather have that than the Asus Hero.
While they have a rich feature set, with for example a USB 3.1-frontheader, there are still some compromises: the Taichi has a slow WiFi-chip
https://us.hardware.info/reviews/76...ards-round-up-17-times-coffee-lake-conclusion
The Taichi's wifi is apparently not very good.
Not that I'd recommend a motherboard based on best wifi but you did express a wish for it. Could always add a PCIe or USB wireless adapter if it's not up to scratch. Even with that it should still cheaper than the Godlike.
The MSI Pro Carbon AC has better wifi twice the speed of the Taichi.
It's difficult to say which is the best brand, as models differ, and companies choose to make certain things better than other things, to target different sectors. Some place audio high up the list, others overclocking, customer service, etc. So it's all very subjective. There isn't really one brand out of Asus, ASRock, Gigabyte and MSI, that ought to be avoided at all costs. It's personal experience, like/dislike.
i see what youre saying but which is THE, hands down, BEST motherboard for gaming performance? Like, "THERE CAN ONLY BE ONE!" decision. And I will take your advice on the wifi usb.
Thats only £289.99, why is MSI Z370 Godlike gaming £504.50?Look into powerline adapters as well: https://www.overclockers.co.uk/networking/powerline-home-plugs
the best for gaming performance would probably be the best for overclocking the cpu (and memory, to less extent), and reviews constantly show that there's very little between the boards. some may squeeze 100mhz more than other boards, which is really inconsequential. in any case, perhaps you may want to have a look at the asus maximus apex: https://www.overclockers.co.uk/asus...et-1151-ddr4-e-atx-motherboard-mb-6af-as.html
It's an overclocking board with only two RAM slots and no wifi. But it does come with two Ethernet jacks and one of them is 5G, if you ever use it. https://www.anandtech.com/show/11860/z370-motherboards-asus-asrock-ecs-evga-biostar-msi-gigabyte/3
You'd need a case that can fit it as it's EATX, and a PSU with two 8-pin EPS power connectors (which not all PSUs come with).
