[TW]Fox;14917213 said:You sure, its at the top on my E39?
Do you have some sort of filter that alerts you for anything BMW related?
Dont suppose you would post the settings up for the G25This is pretty good actually after you spend a good 4 hours trying to fix the horrible default control settings for the G25.
He did on the previous page![]()
Cleared all of those except the drift events which again I fail misserably at them because they're all RWD based cars. They disable all driving aids so every car in these events have psychopathic handling.
so can these cars be tuned more in-depth and tweaked?, or are they just buy on upgrades?
I take it if you're a sim racer its best to avoid this game because it's more arcade biased?
Grid was horrendously poor.
Can anyone advice me how to fix a car that is oversteering? The back end keeps stepping out whilst going round corners.
Should i be moving the balance to oversteer in the quick tuning or the other way?
Sorry for the daft question.
so i basically just tweaked the initial settings.. i did spend a good few hours arsing about with it but then reset it to default and made subtle changes..
Think GRID but with a control system that only has an on/off throttle and sends you into wild slides with even the lightest of steering touches.
If you're into sim racing, this is not your cup of tea. EA might have hyped it as a sim but it is anything but and the only people i've seen call it a sim after playing are people on the NFS forums who describe Underground 2 as a sim ("theyve moved away from arcade and gone back to being a sim like with underground 2" :/) and have never heard of stuff like rFactor or iRacing.
[TW]Fox;14919244 said:Cockpit view has annoyed me - the temp guage stays cold all the time. I mean come on, if they couldnt be bothered to code that in why not draw it with the guage in the normal position?
