need your feedback (pc build)
The board will support 2400MHz memory but some sticks may only run at 2133MHz. However 2400MHz sticks are cheaper than 2133MHz sets and will run at 2133MHz even if they're not stable at 2400MHz so:
Cheapest sticks - i've listed 8Gb and 16Gb sets.
My basket at Overclockers UK:
what about others available that are only few quid more expensive? any better or just same stuff
Only if it's listed on the 'Memory Support List' which guarantees it running at 2400MHz with 7th generation CPUs.
Plus, there's a reasonable chance the above memory will run at 2400MHz if set manually - or via the XMP if your lucky - running alongside a Kaby Lake derived CPU.
But as you were on a tight budget already and you've now had to find another £65 minimum extra- i wouldn't be too concerned about guaranteeing an extra 267Mhz, unless you want to?
i just weatched some test and benchmarks and there is no noticable difference between both speeds so il just go for what u mentioned. question, is this Vulcan memory a good quality ?
Yep, it's good value memory.
OcUK use higher MHz sticks in a lot of their Ryzen builds.
well my monitor is vga but i have adapter that have been included to my gpu which look similiar to vga but bigger.
my windows 7 is fresh, just been instaled. will i have to do new instalation or it will adjust to new components? is it recomended to get win 10 ?
Does it look like this?
You will need to do a fresh install due to the motherboard change - but no need to upgrade to Windows 10 unless you want to?
bud do u get paid for being here and answering to ppl? ;d
MSI GeForce GTX 1060 GT OC Single Fan 6144MB GDDR5 PCI-Express Graphics Card
samsung syncmaster 2232bw
Nope, 2 monitors while i work - and i'm selective about who i answer and tend to stick to a thread until it concludes rather than flit from thread to thread.
This is your card - Clicky
This is your monitor - clicky
You will still need your adaptor to use your monitor with that card.
