Could you try those vids
I linked above too? I'm really interested to hear about the ghosting when watching something that doesn't use TriDef or 2d to 3d. Just watch them in full screen with the appropriate mode selected on the monitor.
i just watched them using both the DP connection and hdmi, and TBH they seemed really good to me, giving the not so great quality of them, but there where certain scenes i thought looked pretty nice, no ghosting
Unless you have PowerDVD 10 Ultra (not an OEM copy) then you won't have 3D support available. That's probably the case, since that is what happens when you try and play a 3D movie in an older version of PDVD Ultra or a non-Ultra one that is otherwise 3D capable.
It's only a trial, but grab Arcsoft TotalMedia Theatre 5 and try with that, it's only a 14 day thing, but it will give you ample time to try it and watch the movie a couple times without any interference.
As far as I'm aware, there are no free players on the market. Very recently a bluray player was put out for free (bit of a first as they had all been OEM or for a premium before that), but not sure if it stayed available, and it didn't have 3D support anyway.
cannot play 3D movies successfully in any other mode except when connected to hdmi
using total media trial,, i played tron legacy 3D and its pretty damm awesome
my power dvd is 10 ultra but i cannot verify its authenticity
but the totaL MEDIA TRIAL works nicely in hdmi frame sequncial
just to add my findings re games using an ATI 6870:
with DVI to DVI connected, fraMe sequential doesnt work, only side by side, whilst playing black ops and F1 2010 and both had severe ghousting
for some reason i could not get 2D - 3D to work it kept defaulting the games to SBS. i think i did get it to go once and it seemed ok,.
the above was exactly the same for mini DP to DP
ok now hdmi to hdmi
using either SBS or sequential worked fine and couldnt notice any real diffencies, def no ghousting, the only problem
i had was in sequential playing black ops, the game played fine
but when the game loads i keep getting wot i am going to call the "white and black screens of almost death" lol
each time i have to do ALT- TAB to go out and back then it loads then,,,
one other thing with DP and DVI i get aobut 43 FPS but with HDMI with both SBS and seq i get 4 - max 24 FPS
