Sounds like useable ATI frame sequential drivers are out for native res @ 120Hz. I'd be interesting in hearing how much better they work/look than SBS.
Shame us NV users are still left out!
I did try shutter mode and all i got was a 2D image...there was no shutter! I suspect this will also start working if I follow the trick to install 11.5b first which i will be doing in the next hour. I will report back shortly.
I've tried iz3d and tridef there booth around the same as can see quite a bit of ghosting it seems that the left eye is seeing a lighter image than the left nOt sure why I'm still looking into it
Crossfire does actually work with the drivers I ported but not working properly there seems to be some sort of flashing with the image
Success now with Tridef at 120Hz using DisplayPort!
I have to disable the crossfire of my 6990 by using RadeonPro (as catalyst drivers don't show a disable option for the dual cards).
I can't get IZ3D to work but I think this is because Tridef and IZ3D are interfering with each other. With the bundled samsung version of tridef you cannot switch it off! Even if you don't start the game from the tridef launcher the Tridef driver still intervenes!
Anyway at least this proves I can get 120Hz 3D working. I agree the ghosting isn't great. I can see some additional sharpness/detail over SBS. I wouldn't say it was Heaven and Earth difference though but I think that maybe because the ghosting partly distracts/removes some of that gain.
LFD2 works quite well if you leave the depth at 50 and then raise the adjustment for infront of screen to 70. Then the guns you hold are infront of the screen as if you are standing outside the screen shooting in...pretty cool.
Good to hear. What kind of framerate are you running when viewing 120Hz 3D on the titles where you notice the ghosting?
Sometimes people also use 'washed out' to refer to a lack of distinction between subtle shades - which is something most TN panel monitors are quite weak at, especially if their contrast is poor. Sometimes they may have seen and become accustomed to certain details in their favourite game titles and when these details disappear they notice it. Personally I reserve the term 'washed out' for noticeably muted or bleached colours but I always support this statement by highlighting the specific aspects I am referring to.
It is not beyond the realm of possibility that Clippa does have a poor unit
either way if he isn't satisfied he should certainly be notifying OcUK of his desire to DSR the monitor ASAP.
I mean all of that, there is very little distinction between subtle shades, looking at photographs, everyone looks airbrushed and made of plasticine.
In videos, everything looked bland and flat.
When I got the monitor, I had to check that it hadn't defaulted to a 16 bit colour depth, that's how instantly noticeable it was. The banding in games was atrotious.
When I had both monitors running together, I took a few screenshots in left 4 dead 2 to compare them side by side and the difference was massive. The 950 looked totally washed out, there was lots of banding, a lack of definition, the colours was washed out and less vibrant across the board, even the punchy blue sports car at the start of dark carnival looked muted and dull.
I tried every combination of settings to get this monitor to look good.
One way of making the colours more vibrant and punchy was to lower the gamma slightly in my gpu settings, tilt the monitor back slightly and ramp up the contrast on the display.
The monitor then started to get closer to looking half decent but of course it was useless because these settings totally destroyed the black levels and bright colours from about 26 upwards here - http://www.lagom.nl/lcd-test/contrast.php were just a block of the same colour.
Yes, I agree, either people are used to bad screens and notice no difference, are exagerating how good the panel is, or I just have a bad egg.
the samsung 245b is by no means a great monitor, a new modern 600 quid job should be blowing it out of the water in every respect.
So far my experience with 120hz has been bad, my 245b has put both the 950 and the lg I tried to shame.
120hz is very nice, I want it, but it's been a real pain in the backside so far
Yeah, it's been all boxed up and ready to go for the last 5 days, just waiting for some parcel paper to arrive.
All I can tell you is I don't see any banding on the test screens on the website. It is a smooth ramp.
If that's the case, then I definitely got a faulty panel.
I just read in russian manual for this monitor that you will be only get 120Hz with AMD HD6000 or above in 3D!!! So all grafik cards like Amd hd5000,hd4000 and Nvidia would get only 60 hz in slide by slide mode. Is this really true? If yes this monitors suck really big
[cut]...
Okay..but I have a side by side image displaying right now and the monitor says its getting a 120Hz signal.
Sounds like an issue of terminology (or plain bad wording in the manual).
It's displaying 60Hz of graphics data being splurted up the wire from the graphics card, at 120Hz by stretching and alternating parts of each frame twice. Just depends where it's being measured from, inputs (60Hz) or outputs (120Hz).
did a lot of more 3d tests, so here are my final conclusions (tested with Dragon Age, DX9):
switched to ati driver 11.5b hotfix, so tridef frame sequential with dp or dvi works now with my Radeon 5870, but...
Display Port or DVI 120Hz:
TriDef FS: works, but horrible ghosting and my eyes hurt (no real 3D Image?)
TriDef SBS: works, but horrible ghosting
IZ3D Shutter: works, but horrible ghosting and my eyes hurt (no real 3D Image?)
IZ3D SBS: works, but horrible ghosting
HDMI 60Hz:
TriDef FS: works perfect, no ghosting (but only 1080p/24 or 720p/60 )
so the only working and really playable mode is the HDMI frame sequential mode from TriDef -> hmm..that was not the reason for buying a 120Hz 3D Monitor
i am now definetly thinking about returning the monitor, looking for an 3DTV (with checkerboard and framesequential modes, like Samsung UE40D7090) or I will make a look to the Acer HN274H 120Hz Monitor.
