just go for whatever is cheapest, the 78003d needs hardily any cooling, in fact you could go for a much less regarded cooler, at an even cheaper cost because the cpu is so cool, and it's not like you will be overclocking it because most bioses, have overclocking blocked on this cpu, I only went for an aio for mine because I wanted the RGB that came with it, if I was doing the build again, i'd just go with a cheap rgb air cooler!, failing that I'd just use the cheapest AM5 cooler that I could find, it's that cool!Do like the look of the thermalight though ?
