**OcUK Extreme Haswell bundle - A review!**
will most of these do 5ghz ?
yes*
*Conditions apply
Conditions
1) When installed into a premium motherboard
2) When fitted with a considerably good cooling system
3) When overclocked by someone with the right knowledge
Tell him to go for the x-oc, you simply don't get the features it offers on any other board for that price!
Water and roughly 1.33v should net you 5ghz on one of these :)
my chequ has arrived going to bank it tomorrow whenit clears im ordering, any chance of adding more coolers to ie. the fathoms ?
Cant wait to get my hands on mine
Even at 4.6ghz, it will be a bit better than an ivy cpu at 4.5ghz. Then you have the headroom to push for higher clocks. Heck even my mediocre 4770k @stock scores higher than my old 3770k @4.2ghz. But on mine, heat is the problem. Ive actually thought about buying one of theese bundles. Using the same mobo i have and sell off the existing kit.
Dedicated audio is usually better but it depends how much of an audiophile you are to how much difference you'll notice.
As for fathom, give scotti a nudge see if its something they can do :)
Ok thanks guys was deciding wether to use the onboard Audio on the Asus Z87 MAXIMUS VI FORMULA or use my Asus Xonar D2X 7.1 PCI-E, was all thanks for the advice.
What Cpu paste are you guys using with this bundle?
