Tubing runs don't look right for some reason, couldn't you have made the loops between each block shorter?
I dont like it, looks too messy
I think you could get rid of a lot of that tube, use smaller loops and it will look lots better.
The order dosen't matter, just keep the loops short and plan the shortest route for them so they dont cross over.
edit; Go from the CPU to the back mosfet bottom connection, then to the top mosfet left connection, then onto the RAM then res. Also shorten the loop from the GPU and the one going to the CPU
Can you not get the 24 pin extension inside the res rather than going over the top?
Is a lovely looking build so far but I always think even braided wires over a res spoils the asthetics. (but then i am a control freak lol)
Bloody finally, loving it so far![]()
Lian Li anyone?
no the led strips lol.
edit also whats the difference between the EK Multioption reservoir rev.2 and old style ones?
LOL this system used to be in a Lian Li, Great cases just not suited for a quad and a double rad![]()
