Bulldog's attitude is one of sheer delight, but he has a point. A simple review done by OCUK would be nice. One an Intel x79 or Ivy... not an AMD system that less than 20% (pulling this from the air) have.
I have a Fathom and I love it. I would suggest that it is slightly better than a H100 too... but it should be given the price.
I would also suggest you make sure people know the dimensional differences between the XPSC and the BlackIce SR1 240. I fell into this issue.
My experience as follows (if I haven't already said it);
1. Arrived packaged nicely with extra Mayhems coolant
2. I needed to change the Rad as I chose the BI 240 and needed a thinner XPSC. I did this myself but buyers beware... check dimensions
3. I therefore drained the AIO solution but unscrewing the compression fittings and draining over a bowl.
4. Once done, I cut the tubing - as it would have been too long for my diddie case - and re-attached them using the compression fittings. These are easy to do and has actually lowered my fear of watercooling
5. I used
this bridging connector to hotwire my PSU
6. I filled the res/block using a funnel and made the pump go on and off until the fluid moved around
7. There was air in the system, so I would screw the top back on and move the AIO solution until the air came into the res/block bit. This meant raising the res/block above the rad with the pump on
8. Repeated 6-7 until the air had gone
Temps are 28-30 idle on cores and never above 65 load using AIDA64.
