**Official ABIT AB9 QuadGT Review/Overclock/Guide Thread**
sulli said:
Thanks loads :) Worked a treat :)
Thank goodness - you obviously have a PS/2 keyboard and mouse as I suddenly realised I was going to have to tell you how to do that using command line switches from the DOS prompt if you didn't :D
BigBANGtheory said:
This board runs under Vista 64, I know cos I am doing so.
Vista 64 is an awkward sod, I can't honestly say your post install driver loading won't be trouble free but it does work.
On a seperate note I successfully modified my BIOS 13 fullscreenlogo today, I can write up a little guide if anyone is interested.
Ok Ive just built my system with this board and a Q6600, only problem is I have bios 10 and when installing Vista 64 it hangs just before its finished installing (just as it says on this thread).
Ive downloaded the new bios version 13, but what i wanna ask is if its possible to update the bios using a bootable cd? On the instructions it tells you to make a bootable floppy disc, but I dont own a floppy drive. Will the bios update just the same from a bootable cd instead of floppy? advice here would be helpfull
thanks
thanks
Sure it is m8, you can also flash from USB pen drive too.
But anyway http://www.biosflash.com/e/bios-boot-cd.htm
cpu voltage help
Hi i have just got my abit quad gt and an e6600 and i have flashed the bios to 13 but when i go to set the cpu voltage it starts from 1.3500 and not lower any 1 know why this is :confused: :(
danielmayne said:
I havent got this board anymore otherwise I would have a dabble. . . .
Try here:- http://forum.abit-usa.com/forumdisplay.php?f=48
If you havent registered, maybe worth doing so. . . all the Abit fanboys/ experts/fanatics use those forums & 9 times out of 10 you will get a reply explaining things to sort out your problem.
Can anyone check the latest :13 bios & see if it only recognises the default cpu voltage & defaults back to the mininum for the cpu?
seems to be the way for abit BIOS of late that they don't have undervolting options.
Of course with EIST etc. enabled it will automatically drop the voltage down when not under load.
UPDATE:The following drivers have had updates, they have been ammended in the original thread.
Note: The date next to the drivers is the date I've updated them, not the actual date of the drivers came out.
DRIVERS
RAID/AHCI Software - Intel® Matrix Storage Manager v 7.0.0.1020 for 2000/XP/2003/64bit 20/05/07
INTEL Chipset Driver v 8.2.0.1014 for 2000/XP/2003/64bit 20/05/07
JMicron SATA Driver V 1.17.18.07 for 2000/XP/2003/64bit 20/05/07
Realtek 8110SC Gigabit Lan V6.193 Driver for Vista 32bit / Vista 64bit 20/05/07
Realtek High Audio Definition R167 Driver for 2000/XP/2003/64bit 20/05/07
Realtek High Audio Definition R167 Driver for Vista 32bit/Vista 64bit 20/05/07
Raid issue
Hi
Had a raid setup with my old pc combination and when i plugged it into this mobo it won't recognise it any idea's?
Cheers
Chris
Chris said:
Hi
Cheers
Chris
What was the old system based on? It's extremely unlikely you'll be able to carry a RAID array across from one controller type to another. The only one I know definitely works are the NVRAID controllers and anything Promise based is all interchangeable.
It was a NVRaid setup on my old Asus A8N Premium mobo. Hmm this could be interesting may have to investigate some more.
Cheers
Chris
