Skiddley said:With regards to physical layout, the 8-pin 12v connector is in a bit of a stupid position, particularly when you have a large HSF assembly.
C64 said:It's ALARMING to say the least that it's not even on the abit support section there's nothing for it no utility's no bios nothing it's not even listed.
C64 said:seperate memory speed setting would have been nice (maybe *** bios)?
what separeate memory setting?
you mean set the timings etc? you can do that and the 1t command and cl3 will be in a bios update.
DampCat said:I'm looking to replace my POS P5n32-E SLi. This badboy appears to fit my specs with an E6300 and 2x1GB Ballistix PC-6400. Not sure which to choose from the P35/Pro/-E though.
Im a bit of an r-tard when it comes to fiddly components, so actually how easy is it to use this board? Also, is it worth waiting for a possible revision where they move the molex's around or just go for it? Also, i've tried to look for myself (r-tard remember) but from what i understand it's still a beta bios? or am i misguided. which is likely.
thanks, sorry i suck.
MisterT said:+ Scoobie , you fired your bad boy up yet?
