front to back
Cheers
Thought it blew outwards (back to front) for some reason.
front to back
Did a bit of playing early to try and drop temps and I'm really surprised at the results
gaming temps before ;system 44 now 33C
8800 gtx 85-90 c now 70-75 c
the cpu is the same but at 38c I'm happy the pwm is still a bit high at 53c but as I'm not sure which part of my system this is its difficult to drop !
Any way this is what I did ;
1 cut away the grill on the rear fan to improve air flow .
2 removed all the rear slot grills
3 mounted the psu upside down and removed the plastic dividing the top and rear compartments to extract heat away from the gtx.
I was hoping for a little drop but wow 15c on my card is great
as a bonus its less noise now as my card fan dose not need to work so hard![]()
Is there any side windows available for the P182?
Well heres my latest build of
antec p182 case
scythe kama bay cooler
5x yate loons 120mm case fans
scythe ninja reb B with Silenx 120mm fan(will be replaced with thermalright ultra 120 when it arrives)
8800gtx (with thermalright hr-03 plus cooler)
Q6600 G0 stepping
2gb Ocz pc2-8500 sli ready ram
600w ocz stealthstream psu
Creative X-fi extreme music
all in all this is a great case i havent got around to overclocking this chip yet but plan to have a bash this weekend well as soon as the new heatsink arrives.
hope this gives you some food for thought
abient system temp = 29 degrees c should be ready for some serious clocking
Anybody Painted the inside of their case Black to look like the Special edition?
Think that would look very cool.![]()
Hi there,
I am looking at installing the same PSU with the P182, just wondered whether you had to use any cable extensions?
I believe almost all of them will fit, its just a case of preferance.Hey, anyone know of a good fan controller that will still let the door close??
Thanks.
Al.
Thanks.
Al
I use a Zalman MFC-1 Plus and it works brilliantly.
My main concerns are dust, quietness and cooling obviously. Does it cool just as well with the front door closed and how much noise difference is there with the front door open? Will my Thermalright Ultra-120 Extreme fit and any front panel extras e.g. x-fi and card readers etc.
