I look forwards to coming up with weird things to store in there!![]()
You can take out the little box, it doesn't have to stay attached inside the case.
Sweets?
Switched the fans from low to medium and CPU temp dropped 10c. Go figure![]()
have you modded the yate loons on 7v?
Would that be for lowering the rpm? Must admit, I've only got two running at 1300rpm, but they do seem a bit noisier? I'm not too worried atm, got a fan controller in transithave you modded the yate loons on 7v?
Eagerly waiting your results![]()
marcus you got MSN by any chance? Need some advice on a P182 mod! Got a 120.2 but buying a 120.3, want to mount it either internally on the top of externally on the top. its pretty much like what you did above with the rad on top its just what I need to cut with what etc
