Think about it. The 182 case doors are a sandwich of plastic and metal (metal/plastic/metal) you're now cutting it down to just a sheet of perspex. And a case window serves no purpose.
The front fans get plenty of airflow, the grilles to the side are intake for the case fans. Because the front door is opposite the fans direct fan noise is reduced.
It's a good case however the optical bays need to have screw holes (they just slide in, don't even lock) Bottom HD cage is too close to the fan/metal struts so bloody pain. Good idea with removeable slide out cage though.
Whats it like trying to fit a CPU cooler to the mobo in the case when its a large cooler like the scyth ninja revb? I guess you gotta put the cooler on the mobo on something like a desk?
Should add value to it to sell on than if I sold it on with no case window.
