** Official** Starfield - Mods and Tweaks
And improved image quality. It's a no brainer regardless of your res in games like this.
Visually it's been a saving grace for Starfield.
I would have quite happily put the game down if there wasn't a way to improve the washed out muddy colour palette. It's just poo at stock.
Going to install the DLSS mod tomorrow when the game releases for me. What is the normal value to set "Render Resolution Scale" at? 100%, 50%? This will be on a 4080.
I set mine to 85% but im on a 4090 and it gave me quite an increase in performance with DLSS3.5 and FG. I reckon on lower end cards you should probably start around 70% and see what increase it gives you.
Cool thanks! I'm just going to get the LukeFZ DLSS mod with reshade and see how i go!
edit: changed my mind
I'm just going to use the popular mod by PureDark , really simple video here for everyone on how to install:
Not tried that one but should work, just check the posts section on Nexusmods to see if there's any common bugs that you should be aware of before installation.
Anything above 70 is essentially the equiv of setting Quality mod in other games with native DLSS. Be sure to change the DLSS ini file to call up preset D too as by default it's set for ultra performance preset. (F). At 70% render scale or above you shouldn't see any difference really 1440p or above.
