Re: Re: Overclocking help
don't forget voltages can kill components!
the guide tells you to slowly add a bit at a time, and to one component at a time - I'm not sure advising to up all these at the same time is a great idea.
if the CPU can clock to 2.2, then in theory the memory sounds to be the weakest link, try upping the RAM ONLY first (IMHO), as per the guide (re: my comments if you had read the guide!?)
Dekim - not sure mate, I think it's just value over performance the 2500 offers the better deal?
Elyman - no idea mate...have a play and let us know
Originally posted by Chong Warrior
You've got the NF7-S v2.0 right? cool.
No need to worry about the AGP and PCI speeds, they're locked automatically![]()
To get your PC to 11x200 I'd suggest going into the BIOS and in the same menu where you adjust the speed of your CPU you'll see options about voltages underneath.
Change the top option to manual, this will allow you to change the volt's for for CPU (1.65v default), northbridge (1.6v default), RAM (2.6v - 2.7v default) and AGP (1.5v default ).
Change your CPU voltage upto 1.675v or 1.7v just to be sure of 100% stabiltiy.
Change the northbridge upto 1.7v (which is the maximum you can set it to )
Change your RAM up from whatever it is by 0.1v (so if it's at 2.6v change it to 2.7v )
Try that, if it doesn't work, post back here
Also change the CPU / DDR RAM ratio to the 6/6 divider.
