- 1 Dec 2015
It definitely isn't too small to fit an M3 screw through, the smallest drilling tool in the CNC will be 3mm, it might be tight if it was on the motherboard standoff tool path but it will push/thread in with a little care.
Having a thread would just make it a pain to fit the cube. Take your board out, stick an M3x10mm screw through the hole and screw it into the cube like everyone intended, just like in every other panel of the entire case and every Parvum in existence.
JR
As I've said all the other holes are fine just this one will not accept supplied screws even with force so will widen it myself to accept , the second counter sunk one accepts it fine though .
Its like the top of the midtray is sloped , doesn't look like its been cut at an angle or that the material slopes when milling but its just a few mills from being set at 90 and flush .
I didn't even know Parvum had made holes to support the PSU which is fantastic , just getting the screw through
The front panel to be remade it just purely not realising how thick alphacool stuff was, but hopefully that that can be made for it although will mess up the looks slightly and getting the correct front side panel will tie it all together
Deal of the week
4x8GB 3600Mhz for £300... Mwhaha
