NW - probably your best and easiest solution.Thank you![]()
long as the SSD doesn't cause any problems and is compatible with the amd stuff. I think it ll be fine though.
Sure - press delete on fire up - and check temps.So I put the ram in now and run bios without any storage connected?
How have you got them connected - via your hub?Also at the top one fan is running with no light the middle guy. The fan top right has lit on but not running.
Temps are fine.CPU temp is like 37 atm board is like 32.
You're thinking of the Wraith Prism your CPU came with the Wraith SpireEdit. I thought the wrath cooler had RGB? I guess not : p
How many fans are you running in total, now?I have the tops connected to the hub.
That's a quality 'branded' SSD - if you're in the market for another take look at WD or Crucial if you want to save a bit of money (still quality units).Do you know much about ssds? I have the Samsung MZ-76E1T0B/EU 1 TB 860 EVO Sata III 64L V NAND Solid State Drive coming
Excellent - glad it's working out for you.I'm glad you told me to take out the hd cage. They are both in the lower cage now. Works out so much better
No, we placed the memory into slots 2 and 4 so that your memory runs in dual channel mode. If you look at your screen shot the memory has defaulted to 2400Mhz - we need to set the memory profile so that it runs at 2933Mhz (the speed of your memory). You do this via the XMP - in 'Easy Mode' you can click the 'A-XMP' button at the top and select profile that changes it to 2933MHz.I don't think I've ever set up memory before, why do we have to do that? Is it because we are only using 2 and 4?
You could run 4 fans using the filters that came with the case - less flow restriction. The extraction fans really don't need any filters as these would be extracting the dust you're trapping in the filters (if that makes sense).I'm running 8 fans at the moment. The filters seem to dampen air flow a good bit. I'm using the two connected k2 heatsink fans in one of the sys fan slots.
You have a very roomy case - if you hook up two intakes at the very front (relying on just the case filters) and take off the home made filters off the extraction (as not needed) - you will have enough cooling for your system. Plus, you'll be able to run the fans off the motherboard - and as mentioned previously setup a curve that will keep your fans quiet and cool the system.>fan concerns<
Pump fan is for an AIO - and will be running the fan at 100%.Pump sys fan runs faster at 1000rpm that's the back extraction one at the moment all others are like 750rpm. I presume the others that arnt sys fans are 1000?
The Windows 10 install process will do this. No need to connect it to laptop - let the Win 10 USB do its thing.I think is that what I've gotta do. When the SSD comes tomorrow. I need to plug it into the laptop and format it fully as just empty space.
i just like talking through my thoughts and plansEdit. I've found the boot options list. I presume the usb will either appear in the list. Well there's a few. Uefi hard disk. Uefi usb CD/dvd. Usb key. Usb hard disk. Maybe I select usb hard disk then boot from that. Don't worry I ll watch someone do it so I can seei just like talking through my thoughts and plans
make sure that it's (UEFI USB) the first first bootable device
You should be using the download tool Clicky to create your Windows USB. (All in that YouTube clip(?))To make things simpler I've purchased a serial . From the bay. Normally I'm totally against paying for anything if I can get away with it. But Microsoft offer the download and compile onto the usb , I can use the usb in the future for free installs and whatever. Just seems easier to do it the more legal way this time
Probably the case button - hesitant to suggest - but you could try connecting the case reset button as a test (perfectly safe).Surely this means, there must be a problem causing this. And it must be either with the PSU, GPU or case?.
